M.O.T Failed!
Car  Fiat Panda 100hp
I'm gutted, I knew it would fail, but its going to cost me £268 to put right :mad: I havnt even got the money.
Nearside front direction indicator slightly discoloured
Front master cylinder fluid close to minium level
front (both) drag link end ball has slight play
front (both) brake disc slightluy worn
front (joint) exhaust system has a minor leak of exhaust gases
O S F for lamp lens broken
One of the bulbs in inop (wtf) in centre stop lamp
both front tyres worn on edges and slight slight cut in thread
__
Gutted
Thats quite a few problems, though to be honest you could fix some of them yourself and save some money. Changing the bulbs for instance is easy and takes 5 minutes where they are probably charging you half hours labour.
__
Gutted
also you've only got 10 days to get it done before they make you take a full M.O.T test again ..... do it all in one day from the day of the test and its free , sorry m8
£270?!
Nearside front direction indicator slightly discoloured If its the bulb a couple of quid, if its the unit, £5 from a scrappys
Front master cylinder fluid close to minium level top it up then! Couple more quid
front (both) drag link end ball has slight play Anti roll bar bush i assume, fiver each and a bit of a pain to fit but not bad
front (both) brake disc slightluy worn Id expect them to be slightly worn! Are they under the minimum width? If so new discs and pads £50-60 for normal stuff?
front (joint) exhaust system has a minor leak of exhaust gases Well seal it up then with some exhaust pste! £2-3
O S F for lamp lens broken fog lamp? New one from scrappies £5-10? Or take both off completly!
One of the bulbs in inop (wtf) in centre stop lamp middle brake light? cant remember if they are sealed in your car, if so get a new unit from the scrappies again and change the full thing, if not get a new bulb! Few more quid
both front tyres worn on edges and slight slight cut in thread 2 new tyres, £60 or so
No need for it to be so much!
nice one john, I have to look up my contacts and see if they can fit the brake pads etc
