megane 225 injectors on Clio 172
Car  RSTUNER'ED-C&B'ED RS-1
Hi All,
How do they work on Clio 172? I checked the std one's on my car are running at 91 % injection duty cycle at high RPM's. Car is not std and running on cams btw.
91% should be fine tbh, they don't fail very often and the meggy injectors will overfuel like crazy without the car being mapped to suit.
They do fit/work but they're only really used for boosted applications as the capacity just isn't required.
Hi Mate,
Yep I am well aware of the need of remap. Henk from Fastchip is the guy to visit. He is the ultimate RS Guru on the planet.
I have read around that 80 % and over IDC is not very healthy but again it might depend on the engine and/or injector type.
if it's mapped and hitting 91% on just a few load sites I'd leave it. Not likely to cause a problem unless they're running high duty for sustained time.
Yep it hits 91 % after 7000 rpm and it is remapped by Henk. I am extremely happy with the map by the way.
it was mentioned in a previous post on CS, though not remembering who said that, that the meggy RS injectors have nice flow pattern.
I sourced a full set at a very decent price so that's why I am thinking about putting them in.
yeh true, im just peeved as ive worked through a few sets, so i dont get along with them
the jots of development and mapping hey!
What are you using them for? I would have thought they would be pretty decent for the likes of ITB users perhaps
i would keep your 172 injectors going untill they begin to fail (if/when ever ..). Then you could always trie the Meg ones ?
You shouldn't really be revving it over 7k much on a standard lump anyway power dies off way before that, nothings broke so don't fix it imo.
I have the sam problem only worse. Discovered today that my IDC is maxing out on 97,5%... not good at all. This on a stock engine with RS tuner generic map, inlet and exhaust mods.
Cams are going in so I must have bigger injectors. How much does the Megane 225 injectors flow?
