meggy 1.4 16v high idle
  182/Bora V5/S1 RS Turbo
Anyone help? as above on a 53 plate. when first started idles at 1000 then slowly creeps up to 2k and sits there singin away. Did have fault with downstream lambda but checked heater feed-battery voltage and it was switching between .2 and .7v. Its the later model no idle control valve so replaced the throttle body. its exactly the same. have sprayed around inlet to check for leaks-none apparent. i found the wires to clutch pedal switch broken off so repaired and refitted=still same. when idling the throttle potentiometer is at 15% im not sure if thats a high reading. anyone know? also when idling the diag machine says idle control inactive.
id have thought if it was drawing air the idle would be irratic rather than constant high.
any ideas chaps?
i blanked off the outlet to servo at the manifold end to rule it out. exactamont the same!!
well it dont pick up any misfire and no faults stored at all. ive had the coils off to remove inlet manifold and when refitted used some silicone grease. they all looked ok no signs of arking or cracks. it actually drives well but sometimes has a flat spot when pulling away but only does that once every blue moon
