Just a couple of quick questions before bed, its had quite a marked past on this forum. Did you replace the injectors as it had various faults pointing towards them and did you get conformation on the timing belt being done?
I replaced an injector and all spark plugs but it turned out to be the coil. Found that out after getting it plugged into CLIP. Not had any problems like that since!
Regarding the timing belt, yes the belt was changed but it wasnt done with the locking tools, it has some tipex there. It pulls well and runs fine so i would say the timing is fine.
Forgot to mention that the injector, plugs and coil were genuine renault items. I kept the spare injector and set of plugs so they will come with the car. Theres also a set of Renault/brembo pins for the brembos there that will go with the car.
