Mk 1 Clio Service’s HELP!
Hello can anyone who owns a MK 1 phase 1 RT please tell me whats supposed to be done on a service at about 60k miles? Can you also tell me whats the one before it aswell? Is it a major service etc?
I have left my service book down at uni, or my mum has lost it, whichever is more likely.
Paul
wqell acording to haynes every 12,000k (12,000k x 5 =60k):
Renew the air filter element
Renew the spark plugs
Check HT leads, dizzy cap and rotor arm
Perform a road test
This is all in adition to the regular 6,000k service which is:
Renew engine oil and oil filter
Check automatic transmission fluid
Check all components (not speakers:sick:), pipes and hoses for fluid leaks
Check condition and tension of auxiliary drive belts
Check the engine idle speed and mixture settings where aplicable
Check the condition of spark plugs
Check the condition and adjustment of the contact breaker points - C-Type engine
Check the ignition timing
Check the operation of the clutch
Check the condition and security of the exhaust system
Check the condition of the front brake pads and discs
Check the condition of the rear brake pads and discs
Check the body work and underbody for damage and corrosion
Check the head light beam alignment
Check the steering and suspension components for condition and security
Check the condition of the driveshaft gaiters
Check the tightness of the wheel bolts
Check the operation of the heating and air con systems.
I would also consider getting the Cambelt n tensioners done very soon as you dont want this to snap!!
Cheers, I ended up ringing Renault. They only told me to check the oil filter, air filter and spark plugs and to think about the cam belt. But that was changed last year to be on the safe side.
Paul
lol- dtwd- i read the first post on this topic and its exactly whats happened to me- i either left my renault book at uni or my mums lost it.
lol
glad to know im not the only one out there-
my problems worse tho- cos the mot certificate is in there and i need to tax the fecking car!
