Mk1 ph2 Clio 1.2 RL ( D7F) Rear speaker wiring loom
Car  Clio II 1.2 16V
The car did'nt vcome with tham as standard. Is it possable to find the loom. going to the rear. and wire them in myself. or get. the right loom from a 1.4 RT. I have load's of old speaker spare 10cm, 13 cm etc. and just after a little better sound.
Ta
Its easy enough to run the wires yourself under the plastics that run below the doors. I had to buy an adaptor as i wouldnt be able to fade from back to front otherwise (it was just a way of turning 2 external speaker wires into 4 and making sure it went into the headunit right) and then off that just run the wire around the footwells and underneath the plastics, the speakers are 13cms, the speaker cases just pull off.
Im 80% sure the loom will be there for the speakers... maybe behind the panel?
on an Energy loom there allways there.... my knowledge is lacking in Dtypes tho
