Mk1Ph3 bonnet scoop/vent help needed!
You can either have a plastic one cut into your bonnet which will crack and look poo or you can stop being a lazy c**t and just fit new lights and get a proper valver bonnet. All you have to do is get some phase 1/2 front lights, theyll bolt straight in, then a valver bonnet will fit a treat, were you got this panels, wings business from I dont know, there the same as every other mk1 Clio.
Get a proper Valver bonnet and a proper Phase3 bonnet..
Cut the 16v Bulge out and have it put onto the Phase3 bonnet.
Quote: Originally posted by cliosportcraig on 10 February 2004
Just modify a valver bonnet to fit a phase 3 and turn it into a bad boy !!
Itll be way too much trouble... and probably not possible.
The lights are much bigger..
:cry: oh well
Quote: Originally posted by dezRT on 10 February 2004
you can stop being a lazy c**t and just fit new lights and get a proper valver bonnet. All you have to do is get some phase 1/2 front lights, theyll bolt straight in, then a valver bonnet will fit a treat.
Ahh cheers Dez, yeah i read about the wings on this forum somewhere, Ill get the lights asap and crack on with it...cheers lads.
