Just after advice really, Small leak from between sump and gearbox.not much, but enough to start worrying i think.!
a, is this a common fault?
b, Is it just the sump gasket leaking?
or c, much worse crankshaft tail oil seal.Which will knacker the clutch as well. And if so can you get to it with the gearbox off, or do you have to drop the crank out.
Would not mind but the car has only done 34k with one lady owner. o well thats french cars for you.
Any advice gratefully recieved.
