mk2 ph2 1.4 idling very low
Car  Fiesta Zetec S TDCi
hi all
excuse my typing cos i just had an op on my hand so i'm 1 handed atm. can't drive for a couple of weeks either :(
i've got a 53 reg 1.4 dynamique which idles really slowly - doesn't actually stall but feels quite lumpy. rev counter says about 500rpm. does anyone know what this could be? car is still under warranty and i want the sunroof looking at anyway, should i mention this at the dealer too?
would like to get it sorted whilst i can't use it.
any ideas you lovely people? :D
Bunz
yeah just tell the dealer, they should be able to look at it with diagnostics equipment and adjust the idle if needed. :)
not sure what mine idles at normally but sometimes it does seem to chug a bit, but it only does it now and then.
my 1.4 16v 53 plate is the same. Bit lumpy idle but when an engine revs low you expect it... especially on a 4 pot. Unless the car shudders a lot its not a problem. From cold mine tends to idle at just under 1k...
They should idle about 800rpm give or take 50rpm and thats with A/C off etc.
I don't know how you think its idling at 500rpm as the gauge doesn't read that low though.
