Mk3 brake caliper question
  Mégane RS
Stupid question really but I think I have a bad piston as the right front brake binds from time to time and is not easy to spin when jacked up, I have changed the brake hose to no avail. I have seen a replacement calliper but it does not quite match the numbers on mine. Mine is 280 (disc size) and 545 or 546 on the outer side of the piston. I've seen one but its 300 and says 530.
What do you guys recon will it fit?
