Mk3 RS200 Yellowspeed Fitting Question
EoinS
  Clio 200 Cup FF
My RS200 is fitted with Yellowspeed suspension (previous owner fitted) and I'm now looking to adjust the ride height up to prevent rubbing / allow some suspension travel.
Having stripped down the rear suspension, I can see that the adjustable top mount (inverted top hat with adjustment threads) has a recess in the top to fit over the locating lug on the chassis. The lug is a lot smaller than the recess in the adjuster, so the adjuster is not located in a fixed position at the top and can move around on the chassis rail. Is this correct? It looks like there should be an insert in the top of the adjuster to give proper location, but this isn't present.
RSRowe
  Megane 250 Cup
Sounds like the rubber cup is missing. I’m certain that is meant to sit above the adjuster. Like this really s**t pic…..
EoinS
  Clio 200 Cup FF
Is that the original Renault part that is used to interface with the Yellowspeed assembly? Looks like the PO threw that away when he fitted the kit!
