BMW 330ci sp/ 172Cup
Hi Folks,
Im interested in improving airflow of the 182 Upper plenum by repositioning the throttle body to a similar position to the 197 inlet.
See my artistic impression below![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Obviously the coil pack would need to be repositioned and a certain ammount of fab work required to achieve this but I think it could be possible. I know from flow benching our matched RS lower that isnt restricting much and also the upper runners work quite well too. We bench tested this part of the Upper and it didnt restrict flow at all:
Flow wasnt reduced either by the throttle body size, more its position and the right-angle flow required from TB to runners.
Why not just fit a 197 inlet? Well, despite my best efforts, I can see people have fitted these (to 197 heads) but cannot find specific details on what is required to make them fit a 182 head. Is it a case of drilling and tapping a couple of extra holes in the head or are they ALL different. Are the port shapes the same or is a lot of matching required. We have a polished 182 head already and it has a well matched RS lower - hence my idea of improving the 182 upper.
Any ideas, or confirmation on 197 inlet fitment to 182 head would be much appreciated.
Finally, this is for a track car with cams and high-comp pistons. I know its not going to make a huge difference but every little improvement helps and i wouldnt mind trying something different.
Cheers,
Nick
Cheers,
Nick
