Monaco 172 Track Car
Wow. Can't believe you are ruining Kyles thread like this.
Let’s ruin it some more
After checking the car over it made me realise that it needs work, however, I have contemplated getting a Z4 for a track car for the last month or so. Mainly because RWD and more power, but the amount of money it'd take to get a nice one, then make it right would be more work than just sorting the clios bits
Plus I don't want to part ways with the car
So the plan will be get the welding done, put together an engine, maybe a full cage and the roof scoop fitting. Then it'll want a few other bits tidying up whilst them bits are underway
So with any hope nothing goes horribly wrong between now and then and I don't have to shell out for something big
Might save you a fair amount of you can find a shell that doesn't need welding, has a full cage and a roof scoop already fitted.
Depending on the cage you'll have to have all the dash out then cut it to fit.
If you want an engine then you'll have to take it out anyway so it makes a reshell make more sense with everything you want to do.
So just use this one whilst he builds a new one from scratch? Your man maths is elite Tom.
It’s man maths level expert but I agree 👍
Just spitballing but how hards a rwd conversion? Youd still have a Clio but a completely different driving experience.
Sierra 4x4 floor pan, maybe a VAG lump in there with the AWD box converted to RWD only. Probably get a VR6 in there. While you’re on you might as well turbo and supercharge it. Absolute doddle.
By different driving experience you mean absolutely awful?
Buying Toms shell and reshelling the car again sounded like a good idea at first. But the more I thought about it the more I couldn't be fucked, I was balls deep in the house renovation, work and I had 5 cars at the time with only 1 working. Buying another huge project wasn't on the cards
#TimeWaster
I was thinking more like body dropping on an MX5 chassis.
#TimeWaster
Tbf I did say different not particularly better 🙂.
Exactly 6 years apart from the first pic to now
Finally pulled my FF Titanium 182 out of my brother's car port. It's been parked there since 2020
There was a hedgehog that had made a little home underneath the cover against the front bumper. At first I s**t myself because I thought rats had been at it
I'll start another thread for the tidy up on it when I get round to sorting bits on it. It felt weird to sit in a standard Clio, I forgot how comfy the standard seats are and high up you sit🤣
Yeah but line item 2 is about 5 hours of fiddling by yours truly.
Then 2 minutes adjusting the shifter
I was thinking about you whilst i cranked my hog earlier actually.
Im tempted to fit the new shifter to the Howdi before CSF. But I also have to drive it 5 hours to get there, so I was concerned about it rattling its tits off the whole way. But then I remembered the whole car is loud. Then I was thinking about how im going to do the haldex service. Then I thought to myself, what is 4wd really. Then that led to me thinking about how much grip a cow makes. Then I got hungry thinking about delicious cows. Then milkshake, cooorr I love milkshake. But I also love beef jerky and thats made by cows. Cows are pretty great tbh. But they also trample people, thats not so great.
Anyway.
Anyway. SQUIRREL!!!!!!!!
Had a spare hour last night so took the time to swap the pads
The old DS1.11 out. They did start to feel a bit s**t at Donington, no wonder. Hard braking zones and minimal pad left which made them go off quick and feel wooden the harder I pushed
New DSUNO in
Swapped the PBS ProRace on the rear to a new set of PBS ProTrack. A bit of a downgrade but the old ones are like 5 years old now
Drivers side back together
Got all the passenger side buttoned up. Upon putting the spring retainers in for the pads I noticed they felt a bit 'slack'. They're newer than the ones I had in there, but the tension on them wasn't great. They look like they're just cheap shite ones. Didn't feel comfortable so I swapped them for the ones I had in before which are genuine Renault ones
So I swapped the drivers side ones back to the original ones too
New DSUNO in
Have you tried CL rc5+ for a comparison to ds1.11’s?? Wanna know if they’re worth the extra cost?
Prob doesnt matter but iirc rear pad retainer usually in bottom mate, just incase as they are bad for letting a pad depart. Them springs are s**t defo reuse oem. I hate these rear caliper design tbh, gtt/saxo ran it and they have always been dogshit.
I wonder if both of my carriers are the same sided
The slither of metal needs to be on the shorter step down in the carrier so they're in the right way. But I wonder if it's been swapped out at some point
Since it was mentioned I got paranoid
I went in the garage this morning and started checking all the carrier I have. I pulled out 4 drivers side ones and convinced myself they're not different. Then the last one I pulled out was a passenger one and it was different🤣
Part number is the exact same so that must just be a Bosch casting mark. Not a part number🙃
Fitted
Last jobs to do before CSF is to get my GoPro mounted so it has a good camera angle (I've 3D printed a nice big bracket), wash the cars, clean my trailer and then load everything up. Got tomorrow and Thursday after work to sort everything
