mot failure - front coil spring incomplete
Car  Monaco Blue 172
guessing i should replace coils & shocks at the same time as they've never been done?
my car is getting on in miles (140k) so don't really want to spend a mint; upgrade is a nice idea but getting/keeping the set-up right seems to be a minefield and to be honest the ride is already hard enough...
rear shocks were done at 95k, should i renew these at the same time to ensure even handling? advisory note says rear springs are corroded. the back end seems to skit around a lot on uneven surfaces, not sure if this is tyres or suspension?
ta
You have a few options
OEM Shocks and Springs
OEM shocks + eibach springs
Koni Yellow + Eibach Springs
Coilovers
having read around a bit on here i've now dismissed apex so yes the OEM shocks & eibach springs are a distinct possibility - i've always found the ride a bit harsh and even more so lately (which is to be expected i suppose). the cd skips when i go over rumble strips ffs!
OE shocks and Eibach springs are a good combination but if you think the OEM springs are a hard ride, the Eibach's will be a little harder.
pro kit - liking the sound of that, don't really want to lower too much as my exhaust already catches on some speed bumps! :cry:
