Mr Pink pins for brembos
Danith
Car  GTi 7.5 pp/Mx5 nd2
Had a set of these ages ago on the megane R26.
Is Mr pink a member on here? Might as well get a set for my mx5 ones if poss.
What exactly is the difference between them and original? A better material?
Stainless and don't have a ferrule for salt and s**t to get inside and corrode everything
Best upgrade you can do because it saves so much swearing. Anytime I've had a set of Brembos I've had to cut and use molegrips on standard pins. Horrible things
They're just undersized pins that use an R clip hold them in position rather than the compression fitting on standards.
Ah balls the mazda ones are different and he doesn't do them. Ah well never mind
As above, they are undersized and use an 'R' clip to keep them in place. They don't corrode and seize in place. Honestly, I wouldn't even bother with OEM and just get some Mr Pink Pins. I don't think he is a member on here but I think he is on 197.net or just search him on Facebook and drop him a message and he will sort you out with a set.
He doesn't do them for my calipers so I'm stuck with oem. Just add copper grease I guess?
