my clio 1.6 running problem
Car  mk4 golf gttdi180
its a mk2 phs 2 2003 on the m5 on he way from wales the imoberliser/diesel heater light came on along with the emissions light so i called out the mechanic/breakdown and he said it was in limp mode because of th imobilser . i thought it was the ciol packs but he then said it wasnt because it wasnt missing .when i was folloing him to the break down yard on the oppsite side of the m5 it started missing and jerking
what is the problm ?
As per your other thread
(was there need for 2?)
Imobiliser won't cause it to go into limp mode.
Sounds like a coil has definatly gone new ones on the 1.6 are £43 each from Renault list price but they can be got cheaper for copy cat parts.
Once you've got the coils chnaged might need to get a garage to clear all the fauly codes in the ECU and even then it might take a bit of driving to get it to clear up check the air filter as well as the plugs and if it carrys on check the injectors.
