Nope HID Kits are illegal.
Send them back lol
Well he did get a bargain for them so he's better off keeping them![]()
Send them back lol
Yeah that looks neat. I will work on interior after i finish exterior cos i want to swap stearing wheel, door cards, seats and audio system but that can wait hehe exterior most important now. Saving up for powder coated alloys now.
that's a major plus because after you've done the seats you can just buy the alcantara fabric and trim your current doorcards (when funds allow, about £30 would do).
I'm looking into the route of just changing the fabric rather than the whole door card. What bits are you going to be painting blue? And I owuld really LOVE to change the dashboard lights to blue but I know that I'd completely mess the whole thing up! lolThats what i want black cards and seats and few plastic bits painted blue electric metallic. Change the dashboard lights to green or blue, replace the heaters control cos the paint is peeling off lol
How easy is it to replace the door fabric out of interest?
No point changing fabrics as door cards are very cheap im gonna paint handles and that greyish stripe above glovebox,and next to stearimg wheel also electric wondows controls and bits and.bobs
Door cards out; remove bolt from inside interior handle, one inside the handle with the window controls and 3 along the bottom. Then its just clips that pop off when pulled in an outward & upward motion.
The fabric just pops off the doorcard. Retrimming is easy and will be as good a job as you make it. Buy a good adhesive and take your time. The technique is very like sticking vinyl when watching for air bubbles. Make sure you pull it round the edges and stick it down. The back can look really messy as its all hidden. The re-fit. Took me half a day all in to do a very good job.
Remove window stickers. Now
Ahh okay, fair point, may do that at some point soonThe big white sticker on the doorand any others you may have.
I've got the elf sticker left on my boot. Dying to remove it, and I will.
I know but I thought I'd chance it, if it's s**t then it's only a few quid wasted and I can get some good ones from the UKGood point lol i removed my yesterday and gomma get rid of the back one too, no problem with removing it they just peel off. I wouldnt bother ordering stuff from hong kong ebay cos delivery takes ages and very often things you order are crap, ordered some smd before and few were not working etc etc
I know, but I'm cheaperSMD are cheap in general anyway.
Free postage? Is it Blue? Where's the link? :LSmd on ebay from uk 99p lol
Try these strips, 15 smd 30cm is more than enough i had to cut mine to fit them along. Do a wiring to a car lighter switch or dome light, dont forget to fuse them with 1-2A fuse, you can get in line fuse holder for 99p of ebay with fuse, switch as well 99p
http://pages.ebay.com/link/?nav=item.view&id=181293937851
They might take a month to deliver lol.
I never saw a fuse holder included a fuse. I bought them separate ended up buying a set of 50...dammit
Yeah, mine were like £2.99 for a set of 4So cheaper than 99p each
That's a question - I've got an old fuse holder but the wire is thicker than the wire I'm using to wire my LEDs; that doesn't matter, right? Also, does it matter if you use a fuse bigger than 1-2A - I suuuuck at electrics! :rasp:
I'm making a paralell curcuit, plus I will be able to remove the solder, just get the soldering iron back outI used electrical connectors didnt solder cables in case if i will want to change somethimg or upgrade i can always just pull the plug out lol
I thought so, just wanted to double checkThe point of a fuse is to break incase the lights go wrong etc. if you put a higher fuse in it probs won't break in time for anything else to happen.
Do you mean that one strip = 0.02A or one individual SMD?one SMD is 20ma or 0.02A.
That's a good shout to be honest, I might just look into that buddyvery nice changes!
if I were you, I would kept the black trim of the original door handle, and replace the handle itself by the metal one... keeping the "grey" trim make the black window controller look a little bit different...
Alright, cheers buddyOne smd its 20ma if you have 15smd per strip its 15x20ma, 1000ma = 1A
