Need help asap! power steering pipe on clio 16v
Car  Clio 172
Hi
Recently I got a new engine fitted to my car. In the process of the old engine coming out we split the power steering pipe on the rack. We replaced the bent pipe with a new pipe and then put the engine back in to find that the pipe leaked badly from the top of the union. We have cut the pipe and put a rubber hose on over the union which does hold the fluid in until you turn the steering wheel left! When you turn left the pipe expands like a big ballon and will pop if held on for to long.
Help needed asap plz cos I want my car back!
I got a new pipe and it didnt work! it pissed out power steering fluid so I need to think of other methods which is where you people come in.
new pipe is the only way, shame you cut it up as you could've taken back to renault uner 12months warranty
EVO, i am beautiful anyway, no need to sleep
get the actual pipe instead of trying some random hose
contact Winston or Taylor @ LTR they probably have one in
LTR - 0161 797 5353
Brun I did get the actual pipe from renault but it was leaking badly! so I guess buying another one aint going to work + its a right cow to fit.
Its the pipe that goes from the top of the steering rack (behind the downpipe) which then later connects back onto the rack (about 8 inchs long) and is metal.
