the belt has nuthin to do with fuel injection, thats preset in the ecu for engine load an revs aint it
Agreed, must be a tooth or 2 out, did you use a renault belt? if so did the white lines on the belt line up with the marks on the pulleys?cam timing no doubt.
The head gasket is under your valves they some times blow if you put it in wrong its easily done you need a new one!!where abouts in the head gasket coz its a new head gasket
