Were looking at a mk2 Facelift Clio on a 2006 plate
The work that i know has been done
A new cambelt
HG replacement (@ less the 60k )
Anyway, it all started when it failed to start - they jumped it, and was fine at first, then the lights on the dash board came on
anyway - the battery had failed, wont hold charge overnight when disconnected
A donor battery to test and it was all fine, it starts and runs after been left - no issues
So with a new battery all is good
Bar the following lights remain on
STOP, serv, EML, ABS
When a code read is done, it returns just 1 code
P0500 - Vehicle speed Sensor A
The code WILL clear, leaving the EML off for a short while
The speedo apprently is dropping out to 0 - then come back
with the return of the Code
However the ABS, stop, Serv lights wont budge
Been to local mechanic, which says the ABS unit is returning the same code as the engine ECU
Since the vehicle has ABS, the vehicle doesn't have a "speed sensor" on the gearbox that i can see, only a reverse switch near the diff output
We seriously need some help with this vehicle
Tommorow im going to have a check of all fuses to ensure when it was jumped it didnt blow a fuse related to the ABS
And with an ABS basic wiring diagram from Autodata - to just quickly check all the sensors wiring from the ABS big connector
Any advice and help is greatly welcomed
Ziggy
A new cambelt
Ziggy
