Hi, Benn looking into the neg camber mods and its easy..
first, heres apic of the front suspnsion lower area with desriptions.
http://homepage.ntlworld.com/captainslarty/172/frontsusneg1.jpg
heres a drawing of the suspension arm and lower strut mount bracket showing where to drill the holes out and whicjh way to bias them.
http://homepage.ntlworld.com/captainslarty/172/drillneg1.jpg
make up a camber reader using a straight edge across the rim and a plumb weight.. the angle can be read from a 20p protractor (Make sure the surface is level)
http://homepage.ntlworld.com/captainslarty/172/negreader.jpg
remove the bolts and insert a very small bolt just to hold it in postion (the bottom arm to lower strut mount)
move the bottom strut mount away from the car until you get the desired camber increase (1 - 2 degrees only)
then drill to take the larger bolts.
the holes can be slotted for greater adjustment.. but only 3 mm or so is needed..
repeat on other side..
there ya go..
all cheques to Captn S. enterprises lol.
Joe.
