New 182 owner, emmisions light flashing and running AWFULLY.
Car  Fiesta ST-3
I've done a quick search and read it could be either, plugs, leads, coilpack or a lambda. Is this correct?
It seems really juddery, and the emmisions light is flashing. Also the whole exhaust including the cat and mani seem to be really shaky.
I'm new to a Renault sport and would appreciate if someone could point me in the right direction as to whether it needs to be renault specialist for this problem, or just a local garage. I'm located in skipton, north yorkshire. Any help would be really appreciated!!
My emissions light wasnt flashing, it was just constantly on and that was due to the lambda sensor. I would go to a renault specialist if i was you but i dont know any in north yorkshire sorry.
Yeah It got fully washed t'other day actually.... however It's been driven a couple of times since. A destructive misfire sounds brutal!!! :/ what should I do?
there's your issue
NEVER jetwash the engine FFS. you have water in your sparkplug wells. In let manifold off, ignition leads out, soak up the water
Bet an injector has gone down.
Unplug each injector at a time, see if any make a difference
