Not a poxy Renault
Fitted my ds2500's and HC discs last weekend to my 182 (24k miles), fitted no probs, left shims in but ground a little from the pad backing for them to fit. After bedding in they have started squealing when hot, as if the disks are not running true. I read a few threads and decided to remove the shims, re-clean the calipers and turn the discs around 180 degrees. After a test drive just now it seems as if the 'wonky disc' sound has got worse on one side, and to be quite honest its pretty embarrasing, sounds as if I've kidnapped a load of canary's!
Any Ideas, can you get HC discs too hot when bedding in to warp them?
