New passenger door handle required?
  FormulaFord Ecoboost
I ad a run-in with a drunk/druggie who decided to jump out in front of my car, my thanks for NOT hitting him was being attacked by his heavy bag which smashed the black plastic surrounding the passenger side handle.
My question(s) are:
- Do I just get the entire handle?
- is it easy to replace or do I need to get someone to do it?
- should I simply ignore it as it's purely cosmetic?
Rob
So you mean the actual exterior door handle?
If so, get in contact with Cliospares on here, ask for one, (will be cheap, it's not a very popular part, and it's pretty small).
The handle is held on by two 13mm nuts, and then you have to clip the rod that opens the door out, the reverse puts this all back in.
You need to remove the door card first, which is easy enough and there's a few guides on here if you need them, once you've done that, it's pretty obvious, just a little bit fiddly.
