Sorry all to keep on about exhaust questions, hopefully this will be the last one!
Basically my exhaust is low at the back, but not because of sagging mounts, basically it doesn't actually use the rear mounts at all!
Could I get an exhaust hanger welded onto the backbox to use that mount, hopefully to hold the exhaust up higher so it its in the slots better?
My only concern is that there seems to quite a lot of pressure needed to hold it up, so I'm wondering whether it will be strong enough...
Reason for the pressure I think is due to some part the exhaust pushing up against the underside of the car, but I'll double check when I get it on ramps
Also, as you can probably see in the photo, the backbox has a hole in it
Fixable? If so, what's the best way?
Many Thanks
James
Many Thanks
James
