Nos Install??
Car  RenaultSport Clio 172 Mk2
HI,WHAT IS REQUIRED FOR INSTALLING NOS IN MY CLIO 172 MK2?:S?DO I NEED NEW CAMS,CONRODS AND PISTONS?:mad:?HAVE ANYONE INSTALLED NOS IN THERE CLIO?;)?
Craig said:
haha. why would you put nos in your 172
Why not ??
I ran a 200 hp 172 unit ( cams, gas flowed manifold, de-cat, R-sport ECU etc etc ) and i ran a NOS system with it. It was powered by a digimax progressive controller running a 50hp jet. The power delivery was fantastic giving me a 13.6 @ 106 on the strip !! You dont need to do much really to fit a kit. If you want to run a 50hp jet i suggest an upgraded fuel pump with bigger injectors, a minimax progressive controller and perhaps r****d your ignition slightly. The solenoids and piping will come with a kit.
Contact http://www.wizardsofnos.com/ for more info and prices
no need to shout..
its Nitrous oxide (N2O) not NOS..
get a highpower wizards kit as pictured in matt blacks clio with a digital progressive controller.
www.noswizard.com
matt - whats the third pulsoid for in your picture on the right hand side?? a purge kit? radiator cooler?
The most important thing is to get bigger injectors and a higher powered fuel pump. Get it mapped up properly ideally with a piggy back ECU & a progessive controller so you can change to and fro when racing. Get the kit fitted proffesionally otherwise your gonna have trouble.
Guy said:
no need to shout..
www.noswizard.com
Purge valve mate
Ran a 75 jet on my V6 with digimax progressive controller - would do 13.5 @ 107
clarkiev6 said:
i aint got none of that and i've been running it for a year!!
speak to wizards mate...
I bought my kit from them and used a fitter recommended by them - i was racing the car every weekend and went through about 10 X 11lb bottles before i shot a piston out of my block. Trev at Wizards said if i had done the mods correctly none of that would have happened ?? - this was 4 years ago and now im very confident in using NOS all the time now as ive fitted many kits and had the required mods done. My suggestion is to read up on NOS and get used to the idea of how it works before fitting it - speak to other people that have it on there cars. The TT is getting a 100hp kit fitted very shortly :D
oh iv been toying with the idea of a 50 shot would be good fun. Plus you compare it to other mods and if set up right its VGVFM
With nos you should be able to run jets which are half the engines standard power.
I.e. a saxo vts = 120bhp so 50bhp is very safe
My mate has 75bhp jets in his VTS, he isnt running bigger injectors or had a remap (yet)
End of the month he should be running TB's, cams and stand alone management. Should see a healthy figure from a 1.6 16v engine
TB's... do you think tb's on a 1.6 16v clio would be worth it or u aswell doing 172 conversion?
cos u could get tb's use larger injectors (maybe 2.0l ones) fire some 50 shot in.. that woud be fun! ;) (while it lasted)
