OBD Port
Car  PH1 172
Hopefully this is in the right place.....
Went round a friends yesterday along with a couple of others to test our induction temperatures as we all have a different set up. We did the test on the Trophy, 182 Cup and then we were going to do mine next. Plugged in the reader to OBD11 Port and the program kept coming up with an error saying it could not read a signal.....OBD Bus or something. Tried it a few times and it didn't like it so we tested the program on the next car (182FF) and it worked perfect. Anybody else had a problem with their OBD Port? I think the problem began since I had my ECU replaced a couple of months ago.....should I go back to the garage and get them to sort it?
If it´´s pre year 2001 only renault can read the codes from the OBD port with their Clip-tester. Same with my ph 1 from 1999
I wonder how people with the RSTuner kit are using them on their PH1 172s if the data is locked?.......
