Isnt the one on the right a ph1, left a ph2?
Oh ok, I read something about them recently on here I must have misunderstood. I'm doing the same process right now.Dont think so, my ph1 has both the rounded bars like the left type
When I replaced both calipers on the cup from dingbro I annoyingly got one of each type
You might be right . The 1 on the left is definitely the same as I had on my ph2 172 and the same as my 182.Isnt the one on the right a ph1, left a ph2?
I had a 306 S16 and that had the same calipers.Saxo VTS, 106 GTi's and 306 GTi-6's all use identical rears as the clio. 205 is the same too I think iirc an old thread
Like Marc says. Thanks Marc !99% of these calipers are now fully remanufactured and not made new so you are now going to get a mix match.
I got @Gus two calipers with the same issue, I than opened up all the boxes until I got got a pair that was matching as there was no way of telling whats in the box until you open it so almost all your places like GSF, ECP and others will just have recon units on the shelf and some will have different arms like in the picture.
It's perfectly possible to do, it's just very frustrating to swap. When you take one apart just remember what order the concave washers go.@Mbeau Thanks mate but I had ordered one already. I cant get a lift in the next couple days either otherwise I thought you might have one.
@Gus Cliosport advice means always do the exact opposite right?Im going to take apart the odd one too see whats what, Id like to have a crack at it but if its just going to cause unnecessary pain then wont bother
I stripped one down years ago . I think from memory there were 4 concave washers. They were an absolute b*****d to get back together. Never again lol.It's perfectly possible to do, it's just very frustrating to swap. When you take one apart just remember what order the concave washers go.
Get some zinc phosphate on there firstInstead of making another thread. Ive been cleaning up the top mounts using bilt hamber deox c, small stone attachment and wet n dry but Im not sure the best way (no powder coating) to paint them to last good. Reason ive stripped them back to raw metal and they start to 'rust' so I dont want to just spray them straight with the vht. Is there any spray stuff that anyone recommends as a protective rust treatment layer to apply first?
Shove a few coats of filler primer on after the initial primerWhats the best way to get them as smooth as possible without slaving away? Ive gone over them with the stone attachment but its a little rough in places.
You mean the top of the top mounts , where the nut sits inside ?Whats the best way to get them as smooth as possible without slaving away? Ive gone over them with the stone attachment but its a little rough in places.
