Oil drain plug thread??
Car  clio 172 mk2
Does someone know which is the size of the oil drain plug in the F4R engine??
M16 X 1.5?? M14 X 1.5??
Let me guess fitting an oil temp sender, bottem of the sum is the last place i'd put it, its the lowest point under the car, get a snadwich plate and runa pressure feed too, pressure is alot more important than temp
yep, you're right!! oil temp sender... :)
What is a "sandwich plate"??
