Hey folks
Ive got a 1.2 2002 dynamique clio as a second car.
Had it for a week and bought it knowing it needed a little bit of work. So I've fitted a new clutch, fitting a timing belt, alt belt and water pump on Monday and doing a full oil and filter change. Will be a great car when it's all done.
While fitting the clutch I accidentally caught the air box with my elbow and doing so I ripped the studs out. So since it was half off anyway I thought I'd give the air filter a quick check. To my horror i found the filter was saturated in oil, to the point where it was dripping from it. So ofcourse seeing this, bad thoughts start going through my head about headgaskets etc etc.
After a quick search it seems to be fairly common on my engine(DAF) but I'm still not too happy about it. So today I took the inlet manifold off. Under it in the little tray where the air is sucked in was full of oil. So using a syringe I drained it and cleaned the residue up with rags. In total I drained 260ml of oil out plus the stuff on the rags. It's still off just now and I'll look at it again on Monday.
So while it's of what can I look at/check to try and stop it gathering oil again? Done loads of searches and a lot come back with a sticky PCV valve(positive crankcase ventilation valve I think) but none actually explain what it looks like or where it is? Or how much they are to replace.
Or is it just a case of at somepoint in its neglected life(it should have 11 stamps in the book and 2 timing belt changes it's only got 1 stamp and still on original belt
) its been over filled with oil and its over flowed into the air box?
Any helpful links or info would be great. Would especially like to know where the PCV valve is and how to clean it, or if my cars even got one! Lol
Thanks for reading
Greg
Thanks for reading
Greg
