R5 GTT EFI Clio.
Right still doing this wire tracing, managed to locate the oil pressure sensor, so i put my multimeter end into the connection for it, and then tried every pin on the main engine loom connection til i found what one it was, then i labeled it.
Then i did the same with the Water Temp Sensor and it traced to the same pin?
Can someone please explain how this works? i dont see how the oil pressure warning light, and the water temp level instrament can be linked together? i traced the wires and the oil pressure one is a single wire for the sensor and it goes straight to the water temp connector? :S
Any ideas?
Any ideas?
