One complaint with my dynam
Car  Clio
THE FECKING SUNROOF
decided it wanted to leak like a tap last year so took it apart and fixed it wiht a boat load a seal . NOW it has decided to rattle on the 2 brakets and handle
More annoying than the leak if im honest
i relise buy buying a brand new handle for reno will cure it
What about the 2 bracket thingys ?
The rattle is common, although mine doesnt rattle very much. Only have a problem with the front of the dash board. My last clio was a heap of fe r king shi te tho.
Aparantly, if you shove a scouring pad or whatever in between the handle lever thing, it stops.
If there's absolutely, positively one thing you can be certain of in this life - pull a Clio apart and it WILL rattle when you put it back together again!
