Orange Coolant
Does anyone know what brand or type of coolant the orange I currently have in my coolant system is?
The service history for my car was mainly Renault so Im just wondering if its used by Renault?
I know Type D is only recommended, Ive spoke to a Renault mech who says they use all types in the dealership servicing department.
My plan is to fit a new expansion tank with fresh type D anyway unless someone says its fine.
I believe the Renault TypeD stuff is yellow so maybe somebody has added something extra into it. Mine atm is green and I topped it up with some stuff that is blue.
type D is a greeny yellow luminuous (sp )colour.
i dont think it really matters which colour it is aslong as you dont mix the two types!
Renault Type D is green, if your car had a coolant change at the dealers on the cheap they may have used Motrio coolant which is orange/red.
Yeah I used Type D when changing my grandads 1.2 coolant, Its like radioactive piss.
Cheers Alastair that sounds like what Ive got, its orange red. Will try and change it for type D next service.
I've got a quick question... does the car need to be hot i.e. thermostat open, and will this allow ALL the coolant to come out.. Because like said Id rather flush with water and not have any mixes of coolants.
My top tip would be to not let it drip onto you... smells like fishy ***** and doesn't wash out easily... especially your hair ;)
renaults own coolant is green and it goes orange with age.
​2 types of motrio stuff one orange one blue
get some decent coolant system flushing fluid and put it in with water. flush it through, empty and refill with TypeD.
all i did was put a rattle can cap full of TRF in the coolant tank filled the system with water, ran it upto temp, dumped, flushed with fresh water and then refilled with typeD
So dump the old, put the hose back on fill again with fresh water after flushing, let that cycle round and then dump the water and refill with coolant right?
yes.
dump old, hose ( s ) back on
fill system back up with water ( add coolant flush with it if you wish) run upto temp
dump again
refill with type D run upto temp and bleed the system.
remember to turn the heaters onto hot to flush the heater matrix through aswell.
