PAS sensor/switch front bumper remove?
  Cup In bits
2 x 10mm nuts for the rail guard. I don't know how you can't do it then, fiddly right enough but you should have more than enough room buddy unless your PAS pipe has been bent.
Yup.. did mine a month or so ago, I found space a real issue, but was doing a PS fluid change anyway so disconnected the pipe from the pump and brackets and pulled it up which made it a piece of cake... maybe worth doing a fluid change just to make it easier .. ?
