Paul’s Pearl
Booked the clio in at Diamond Motors for the steering rack checking and or refurbishing. My research turned up a few instances of steering racks going sloppy on early 197's and I'd hope Renault had sorted the issue by the time the 200 was introduced but you never know. I saw a post of Mick's about steering racks and steering feel so he's the man for the job.
Besides that the car has been running OK. The stereo has been a bit s**t sounding for a while now and despite the Alpine head unit the speakers are 14 years old so it's time for a little upgrade.
I've seen people swapping the HK set up in M2's for Audison kit so it should do the job in the clio. First I need to pad out the flimsy panels with sound deadening though.
And as I don't think I've ever swapped discs on either of my clio's and the fronts look a bit puny behind the 18" Turini's I snapped up some megane 3 brembo calipers from @JamesBryan which I'll pair with some 330 diameter godspeed discs for more stopping aesthetics 😂.
I just need to decide what colour I want the calipers as the rear ones were replaced and aren't even painted to match the red fronts. I'll just use oe pads and upgrade to braided hoses when I fit them.
Whats the symptoms of the rack? Dead spot or just vague?
My kangoo runs basically the same rack..still on the original diesel one 150thou ish. Wonder if its contributing to the torque steer🤣 the mrs was driving it last week and she said its not that responsive.
Looking at the Godspeed kit i think all they need is a small spacer which you'll be able to knock up in work.
Being a white car, a fresh silver colour might work?
The godspeed kit come with spacers, I believe it's just a 9mm spacer that's required though so I could easily knock some up. The BM has silver calipers and I think they need to stand out a little bit more. Maybe a light blue as the pear is slightly blue on the car 🤔.
Ahh ok, yeah i've only seen pics of the kit and the spacers didn't look too thick.
Maybe do a few Photoshops of your current brakes to see what colour works.
Dead spot going straight. It feels like there's a degree either way that doesn't do anything, it's as if there's a coupling that's got some backlash in it, that's the best way I can describe it. It was like that on our last Wales trip a couple of years ago and I figured if it was going to break then so be it but loaded up in a corner it feels fine and drives like a cliosport should. It's just everywhere else I feel like something is about to break or fall off 😂. I'll be sure to update when it's been in but it's not going until October!
The 200 cup came with a different rack, not sure if yours is cup packed Prorl
I may have a set of standard 250 pads, pins and rattle clips you can have (If they're still in the garage)
Yep it was cup pack equipped so has the shorter rack. That's why I'm more keen on having it refurbished than buying a used one and not knowing what one I'd end up with.
That's very generous sir, I'll swap for some if your favourite confectionery if you find them 👍.
Mine might be the same, does feel a little numb moving it when going straight.
I best start looking for a 200 cup rack. Im sure its shared with a scenic or something similar from memory
If the cup rack is on some random Renault get buying them up and selling them onto unsuspecting 197 owners on Facebook for a nice profit 😂.
Stripped some of the car out to start fitting the sub and speakers. Then the amp I'd ordered got delayed so I've been driving with half the interior missing.
It's f**king noisy! Which reminded me I had some sound deadening stuff buried in the garage so I'll be adding more weight by covering any surface I can with it.
Anyone wkow what these plugs are for that are hidden behind the passenger side panel?
I'm going to book a week off work to get the stereo sorted and might even fit the new engine mounts I've had a year as I think the exhaust flexi is blowing now. No point replacing that with worn mounts as it'll die again quickly.
Amp and wiring kit arrived the other day so I cracked on today. First job was to remove the glove box and the air box and find a place to feed the power cable through. JBL amp got good enough reviews and only cost £200 and the Vibe wiring kit was easier than ordering everything separately.
Lots of bits to remove to see the bulkhead though 🙄.
Getting the battery box out was a right faff as the fuses that are clipped to the front of it just wouldn't come off. It took a lot of space in the swear jar to get to that point 😂. Plenty of room to drill a hole and put a grommet in so all is good.
Except the battery for my drill was dead so time for a cuppa. 30 mins later and hole in, deburred both sides and painted before drilling a hole through the grommet and fitting.
Sorted.
Then I had a great idea! While the battery etc was out I may as well fit the new gearbox mount I have, it's only 5 more bolts.
The old one didn't look too bad, just a little bit squished, old on the right. But it's 14 years and 80k old so in with the new one.
Now those bolts that hold the mount to the bracket are the shittiest idea ever. Take the nut off and the bolt drops out and hits the floor. Getting the f*****s back in on your own is a ballache. The one not in the pic above needed feeding in while laid under the car and as I'm not Mr tickle getting the nut on wasn't possible. After a very long time pissing about I eventually found a magnet to put on top to hold the bolt while I shoved a piece of foam under the bolt to stop it falling back out as soon as I looked at it from above. This is a 1 minute job with a helper available!
While doing this the wind had got up and tried to blow the bonnet into the windscreen. I was shocked to see the bonnet off the support bar and just balanced upright! Quick safety strap added 😂.
With the mount swapped and the power cable routed and secured I just needed to refit the jigsaw of airbox, intake pipes and battery box. Notable annoyances being the inlet air pipe has a pipe on the bottom from that weird cannister thing that was a pain to refit and the battery clamp was an absolute c**t to get the bolt in. Plastics got a little wipe before refitting and it all looks neat and the car even started straight away 😁.
Cleaning bits that never get seen 🙄.
I need to connect the power cable still and figure out where to put the inline fuse.
The interior is even more spartan than before but that was enough for today.
Luckily Saturday was dry so I cracked on. First thing to do was remove the head unit to connect all the required cables. This isn't as easy as it sounds.
Having a connects2 module to use the oe steering wheel remote means there's a massive rats nest of wires and plugs tucked up above the radio and the only way to get to it is with the glove box out. After disconnecting that and removing the radio I was dismayed to find 5 colourful wires unused. I need to connect the remote power on to the amp but which one is it🤔. Amazingly I still had the instruction encyclopedia for the head unit and after studying the wiring diagram for an hour or two I found the correct wire. With that connected and the rca cable connected the head unit can be reinstalled while coeecing the cables carefully out the side so the connects2 can be connected and then the whole lot tucked away again ready to catch fire.
Then with all the trim out the car the four cables just need routing to the boot. A bit of zip tie and using the oe cable clips it's all tucked away nice and neat.
I found the alarm siren hidden behind the boot carpet including a strangely placed flashing led!
And renaults attampt at sound deadening in the rear quarters 😂.
I'll add to that another time.
There's a conveniently placed earth behind the boot carpet too so after connecting the cable and routing it the interior was refitted.
The boot carpet didn't sit flat due to the cables coming out under it so I set about neatly trimming it which was easy with a sharp Stanley knife.
Doh! I just need to connect the cables up and secure the amp to the boot floor or maybe the sub box and it's good to go. I ran out of time on Saturday so it'll have to be finished off this week and then I can start rattling the car apart 😆.
I pulled the head unit out again yesterday and without adjusting any wires the steering wheel controls started working 🙄. So onto the important stuff in the boot. Fist up sound deadening.
A layer of dodo mat deadn hex covered with dodo duo foam does the job by taking all the tinny feeling out of the boot floor. Carpet on next and some trimming so the cables route nicy and then the amp and sub in and secured in place. Nice.
Could do with a piece of carpet to cover the cables on the left, why the speaker cable had to be yellow god only knows. Fired it up and nothing caught fire so fiddled with the bass settings in the head unit and it didn't make it's presence felt at all. There's far too many settings on the head unit but the one that was stifling it was the boost controller in the glove box. Gave that a little twiddle and we have bass, proper bass too with no rattling or nasty vibrating 😁.
So onto the front speakers. The Internet says the door card has to come off which thankfully is bolloks as the speaker cover just pulls off.
Oh who put that there then? 🤔 Ah that'll have been me as they were bought for my daughters first twingo and her second one had upgrades already. A bit more digging and it turns out there's no tweeters in the dash either so they will need wiring sorting which looks easy on the passenger side and a nightmare on the drivers side. So they are on hold until I can be arsed, I'll see how I get on with the sud and these JBL's but ultimately they will move to the rear and the audison components will get fitted up front. My neighbours will hear ne get home in the mornings now 😂.
Had the car in with Mick at Diamond Motors today hopeful for a resolution to the dodgy steering. It's not fixed but parts will be on order ASAP and a return visit booked. Remedial action has improved the feel so I'm looking forward to having it fixed properly. I'll detail exactly what's done when it is fixed, for now thanks to Mick for his good work.
Revisited Mick on Friday. By far the best car there 😂.
On my first visit he found a couple of issues. One was some not quite tight enough bolts, the first being the subframe ones and also the bottom arm ones. I've never touched the subframe bolts but I did replace the arms, and torqued them to spec but I guess I should have given them another crack after a few miles. That sorted the clunk that happened when braking hard, which I explained to Mick I just avoid braking hard and it didn't clunk😂. Then he looked at the creaky uj.
That's what I received while in the pub 😂. I knew there was a bit of play there but I'm not good upside-down so didn't look at it too closely. Turns out the clamp had slipped down the rack spigot and wasn't clamped on the right part. As a result the uj clamp is bent to buggery mick advised replacing the uj and the bottom part of the column. So parts ordered and a return visit booked. He then reclamped the uj in the correct position and that took out the slack as a temporary fix.
So I returned on Friday for the new parts fitting and between Mick ordering them and going to collect them they had suddenly become NLA. The clamp is available still but the extendable part of the column is a no go. 🙁 So after a quick inspection of the clamp Mick declared it had stayed put and would have to do. It does feel a lot better than it was but I might see if I can nab a second hand column for a future swap over. At least it doesn't feel like it's about to fall apart now.
MOT is due in a couple of weeks but it needs some mods to the exhaust first and the lights needed changing.
Fog light works now 😁. Booked in Friday for the exhaust so I'll update then.
Dropped the car off at the exhaust place but had a slight change of plan which upset the gaffer there. I had asked them to fit the cat in and look at the flexi as there's definitely a leak up front. Turned out the leak was the pre cat which has a hole rusted right through it! So fit cat and patch hole was the plan but now I'm thinking just get a new manifold and fit the main cat in place of the pre cat in the new mani. Boss ma's was a bit miffed when I said I just want the hole patched, understandable I suppose. Now my dilemma is do I order a Gravity manifold which is £199 on black Friday or do I buy a Pure Motorsport one for £800 which we all know will be miles better quality. 🤔.
I had a Gravity on my 197, sounded alright tbf. But the flexis on it didn't last long, maybe around 4-5 years. I'd imagine the PMS one will be more robust and it probably sound better too.
Yeah the guy at the exhaust place said he'd posted on their Facebook page that they wouldn't fit any gravity parts after a struggle with one once 😂. It'll be getting modified for the cat though so I can't really justify £800 to then be chopped up.
Just picked the car up and it's stopped farting which is nice. 🤞 It passes mot next week.
Had a drive to caffeine and Machine yesterday. Weather was crap but a decent turn out of renaultsport cars anyway. Coffee was s**t too so probably won't go again.
Didn't take many pics because my camera lens is cracked. It was good to give the car a decent run as its only done short trips all year, 200 miles at 32 mpg so it too bad.
And today was MOT day. Remember last years cluster f**k? Well the tester did and he said let's hope it's better than last time 🤣.
Thats only the third time it's had a clean pass in its life! I was relieved that the emissions passed with just the patched up pre cat. My new gravity manifold arrived too last week, I'm going to ignore that until spring now then I'll open the box and see how s**t it is. For now though all is good 😊.
Bloody thing ran fine this morning and tie evening so maybe it doesn't like long runs, when the eml came on I'd just been up to Bradford to see Kyle 🤔. It's due a service so I'll sort that and see how it goes. Best join green flag just in case 😂.
Dodgy lambda? I took it to tesco this morning as I the fuel light was on and it ran like a biatch, it sounded like a scooby and pulled like a g whizz. Tesco petrol station was closed too🙄. It even spluttered when revving while idle and the tick over was lumpy. Of course as soon as I got home it ran as smooth as a Rolls Royce and even pulling away in second didn't phase it. Looks like the M2 will be getting dirty.
Sounds like dodgy injector/s and the o2 sensor is seeing rich/lean.
Also with it sounding like a scooby that's usually indicative of injector malfunction from my experience
I'll have a butchers. The knock sensor is at the front and apparently suffers from weathering and brittle wiring so I'll have to have a look at that too. New ones are £250 though 😳.
Be a wet or knackered coil, or plug, injector etc. Find the cyl in question and swap parts. Clip tells you which cyl has logged misfire, torque is a bit sketchy
