Pc help
DrR
  VW Golf GTD
My bro's comps is broke, his silly gf moved it while it was on, now for some reason just after the pic of windows xp with the blue bar that moves underneath it just freezes, black screen nothing.
Runs fine in safe mode?
try doing a system restore in safe mode
if that doesnt work
try booting from the xp cd and go into recovery console and run chkdsk, see if that helps
Give all the connectors inside the case a push, just to check that some haven't come loose... :)
ARRGG had to reformat it, took everything out and put it in, no difference!
Read the above posts,its Hardware
I.E Something's loose,cable rubbing on a fan,Loose IDE cable to HDrive/MBoard
Open her up and chek all connections
