It suggests changing the pedal sensor if the fault persists Sam.
INJECTION
Fault finding -Interpretation of faults 17
DF126 PRESENT OR STORED
PEDAL POTENTIOMETER TRACK 2 CIRCUIT
CC.0 : Short circuit to earth
CC.1 : Short circuit to +12 V
NOTES
Priority in the event of a combination of faults:
–Deal first with faults DF219 Throttle potentiometer reference voltage and DF220
Pressure sensor reference voltage if they are present or stored.
Conditions for applying the fault finding strategy to the fault stored:
The fault is declared present after:
–switching on the ignition and pressing the accelerator pedal.
Special notes:
The accelerator pedal position sensor is located on the bulkhead below the brake servo.
There is no need to program no load and full load position recognition.
Check the connection and condition of the pedal potentiometer connector.
Change the connector if necessary.
Make sure that the accelerator pedal moves the potentiometer correctly (from the minimum end stop to the maximum end stop).
Connect the bornier in place of the computer and check the insulation,continuity and absence of
interference resistance of the connections:
Computer connector A track K1 Track 1 of the pedal potentiometer track 2
Computer connector A track F1 Track 3 of the pedal potentiometer track 2
Computer connector A track B4 Track 5 of the pedal potentiometer track 2
Repair if necessary.
Check for the presence of a 5 V supply on track 3 of the potentiometer.
If there is no supply,change the injection computer.
AFTER REPAIR
Clear the fault memory.
Follow the instructions to confirm repair.
Deal with any other possible faults.
Hope this is of some help mate
