ph1 172 lambda sensor quiz!!!???
well mine has 2 and i oredered a ph1 decat only to find its an inch to short and only has 1 lambda sensor, sent it back to have it exchanged for a ph2 item, I didnt even know some ph1's have 2. and also there wasnt anything on there site saying to check if it has 1 or 2 lambdas. ordered off ktec btw.
Get under the car and see how many lambda's it has they changed the cat mid production on the phase 1 172
Early phase 1s have a twin cat so have a pre and post O2 sensor. The PRE is the one that needs changing if fooked.
Later phase 1s have same cat with one sensor.
Twin sensor
Single sensor
And yes a knackered Lambda will cause hesitation and spluttering under acceleration. You can buy them for around £50 on eBay, I use Bosch.
All mine are twins, two of them 2000 and the other 2001.
The exclusive had similar issues to you, hesitation under load, poor mpg, and a rough idle. Changed it and all was well again.
