Ph1 badges part numbers? Availability?
Paul172sport
Car  Sunflower Ph1
Hi
Anyone able to help with the various part numbers for ph1 172 badges.
So
Boot 'renault' 'clio' and 'sport'
Along with front diamond
On the mouldings the 2.0 16v ovals or even the exclusives ones?
Long shot but any help be appreciated
More than likely all discontinued but il try source some random bits.
The boot badges are the same as ph2 arent they? I've got a full set of boot badges here, no double sided tape on them though
You can buy the Renault badge off eBay new for £15, these just push into grommets as does the Clio badge which is around £8 used.
The Sport badge is £50 from Renault new, I managed to source two used ones for £5.
This badge needs to be stuck on, I cleaned up the rear and used 0.5mm 3mm double sided tape.
I was looking for the oval 2.0 16v phase 1 badge, but didnt find one in months of looking (Argument with a supermarket pillar- Pillar won but drove off without seeing the badge had gone)
Ended up getting a replacement 16v oval badge for £6 off ebay. If anyone has a cheapish 2.0 16v badge...…..
