KitsonRis
I need to either splice a new throttle position sensor onto my Ph1 loom or swap the throttle position sensor from a Ph2 to my Ph1 loom. I am struggling to find a wiring diagram. Any help?
So I need to go from this Ph1 loom plug:
To this throttle position sensor:
I would prefer to use a Ph2 plug and not cut the brand new sensor. But if I go down that route of splicing it I will make sure there is a removable connection just in case.
There is method in my madness....apparently Ktec have updated the TPS in their ITB kit where previosuly it had an adapter cable to go from the loom to the supplied sensor. Now you don't need this. But being a Ph1 it doesn't quite work (by the looks of it I might be the first to hit this issue as it was new to them when I phoned them earlier!). Their solution was to get a Ph2 plug and use the new connector on the sensor or cut both plugs off and splice the loom to the sensor. I have asked them for a wiring diagram but just in case was seeing if anyone has any info. Have also posted in the wanted section for a Ph2 loom plug.
