Mertin
								Ph1 172&Ph2 172 Cup
				In the coming months Im about to fit an itb setup & adaptronics ecu that was removed from a ph2 cup to my ph1. Going over a few things to check their compatible / forsee any issues Im going to have. I'll be closely comparing both looms once I have mine removed.
I have the whole engine loom including fuse box / relay's from the ph2. Is anyone aware of any issues where they wont be compatible, main one I can think of is if the white plug was wired / pinned differently between ph1 / ph2
Usually main difference is the throttle cable / speedo drives but given that its on itb's then this should rule out that side of things and ph1 is also speedo drive so ties in well with the cup loom
On the ph2 loom Iv noticed that the lambda plug only uses 2 wires whereas most if not all clio lambda sensors are 4 pin. Anyone know of any reason why the heating side of the lambda has been done away with?
