Ph2 172 cup.....lower weight the only difference?
Car  200T & 172 Project
I did a few searches but really couldnt find a answer so i'm sorry if it has been discussed loads. I have been offered a phase 2 172 and after some research 90% say the cup is better and faster but all ive found is the difference is suspension and weight saving.....is there anything different between the two i'm missing like engine etc?
Just wondering as everyone talks about the rawness of the cups and if I got the stock 172 and did some weight saving and properly set up coilovers would it be just as good as a cup?
Tom
im pretty sure all cups have RS inlets? i know the ones i have seen have them anyway
Different aux setup so cheapper major services and less drag on the engine due to shorter belt and no compressor.
No traction control either, slightly wider track? No headlight washers, no spare wheel. A number of things really
If you get truly geekty theres quite a few bits missing/different
Possibly the most geeky is the 3rd rear belt isn't there. and the windscreen is different
Gearbox is the same speeds but has a speedo sensor.
89kg total weight difference
20mm wider front track, 10mm wider rear (might be the other way round, i forget)
thinner glass (all of it!)
no AC (unless its a gay later model cup)
majority had RS inlets
no ABS
etc etc
i have a 3rd rear belt in my cup
Are you sure this whole thinner glass business is true? I have the original 172 cup broschure at home, its mentions a lot of weight saving feature, but there is no mention of the glass anywhere.
yep the glass is lighter/thinner, even your door cards are lighter. where they can they saved on weight including silly things!
100% true so if you own a cup and any of the glass needs replacing i would make sure its the right part for a cup ;)
