picture request, internal CC sensor
Car  CLIO Iceberg 172
as above i need a pic of the internal climate control sensor up in the interor lights unit,
at the moment it just looks like i have 2 plugs disconnected, im thinking the previous owner got fed up with the buzz and got rid of the unit,
if somone can post up a pic showing everything that should be up there and where the two plugs should be connected to i would much appreciate it.
so far i cant see nothing that looks like a fan or sensor
bump could really do with this as i cant find one anywhere, the only one that shows what i want was deleted ages ago, in an old thread
If there isn't a unit clipped into the front grill on the light surround then it isn't there. Theres a very small fan in a tube with a little duct type thing to the grill. I'm guessing you can adjust the heater temperature from one setting?
yea its only pumping out hot air randomly and the rest of the time its cold, so looks like a trip to dealers still would much apprecate a pic if somone has one
Hi there,
i think its made or called "bitron" i found all the info by searching for that on here, there was a video showing the unit you are after
BTM/BITRON
300/03
906000210
8200093290 written on it.
Just had a look pic isnt amazing but might help
cool cheers guys, i did look... but that is exactly what im after.... iv found out that the reasion im having problems is that the org connector thats ment to plug into the sensor is unpluged!! so if it is a buzzer dose anyone know if there is a silent replacment or somthing that iv been reading about. if not i shall go to the reno stealers and get a new part...
