PLEASE HELP!!! Clio 182 issues - water in power steering reservoir PLUS other problem
Car  RenaultSport clio 182
Hi all, I'm new here, and well done a silly thing and need help.
I bought a 182 - new - last July and recently have had some problems.
I was getting a nasty knocking noise from the on side area around the suspension columns over the wheel area - renault sorted this out after much trouble.
And after a month since i got it, the car seems to be pulling to the RIGHT - renault state that there is no problem - they havent tried any tracking balancing though - and they say warranty doesnt cover this - but there seems to be - visibly so since i bought it it feels different and my mates have noticed too. It pulls to the right - sometimes it doesnt, sometimes does and at speed the steering seems over sensitive!!
MOST IMPORTANTLY being a total ignorant in regards to cars, I foolishly - instead of topping up the wiper wash fluid with water - topped up the POWER STEERING FLUID RESERVOIR WITH WATER!
WHAT do I do now? car is running feeling fine - but will there be any long term damage? How do I flush the water out and re fill it with fluid again? and WHAT TYPE of fluid do I use?
I notice the engine radiator thingy is located at the rear of the engine bay - do i simply top this up with de-ionised water to keep the level when cold between min and max? or do I use a 'coolant' of some other sort?
LASTLY - on a handful of ocassions the EXHAUST GAS MONITOR LIGHT flashes when I'm idling stuck in traffic or something, and I have to switch ignition off and then on for it to go. This has happened a grand total of THREE times over the last 3 months - the first time was when my missus was driving, she didnt know what it was, left the car on, and the engine cut out! and she had to switch it off and then on for problem to go - following TWO occasions were when I was driving, stuck on the A406 as i described above. The manual says switch engine off OR see renault dealer if light blinks - so what IS this problem? is it serious? what needs to be done?
PLEASE HELP!!!!
i think one thread would have sufficed!!
RE: the PAS system...if u are "a total ignorant in regards to cars" then this sint somethin gu shouldattempt urself. not being harsh, just realistic. i suggest you take it to your local dealer, with a list of ALL the above problems, and get the to sort it.
the PAS system will need to be drained, flushed and re-filled. it depends how much water u put in as to the extent of any damage. i'd say it would be fine if u take it in asap....
with regards the engine rad water level - just top it up with water, you could add a bit of antifreeze to the water as well if you are putting a lot in.
Get the tracking checked over - go to www.alignmycar.co.uk and search for your local specialist - they should sort out any thing wrong with how its driving.
with the exhaust light perhaps your cat is nackered or something - best get that sorted with renault.
