Pollen filter removal
  Recaro'd 182
Hey just read the guide on changing the pollen filter fro the clio 182. Got stuck at the first hurdle lol.
Had a go the other day to get the scuttle pannel off seen below. How the hell do you remove the plastic screw in the bottom left hand corner of the scuttle pannel (next to right hand wing) Does it just pull out or what?
  Lots of Alfas
Push the little centre circle in with a small pointy screwdriver or a sharp pencil, then it should pull out. Once the scuttle is off you will see the little bolts that take the cover off.
