Hi, I have owned a 182 for a year with no issues until now. About 2 months ago it started to miss fire so I put it in to get sorted turned out to be 2 injectors no 2 and 3, I also had the aux belt done then aswell. It ran perfect after that until I was driving home one day at 60 and the engine gave a slight judder, this started to happen every few metres but quickly deteriorated. The car now idles poorly and at cruising speed it will have a kangaroo effect but as soon as you get above 4-5000 revs it will run perfect, just a bit smoky and a strong smell of fuel. The problem seems to be temperamental sometimes it will run perfect on low revs but that doesn't last long until the judder comes back.
so far I have changed
coil pack
ht leads
spark plugs (ngk)
crankshaft sensor
pre cat lambda (car has full ktec de cat exhaust)
throttle body
map sensor
air temp sensor
checked injectors
any ideas would be great
thanks, Sam
coil pack
ht leads
spark plugs (ngk)
crankshaft sensor
throttle body
map sensor
air temp sensor
checked injectors
thanks, Sam
