"Possible" Stupid Oil Change Question
Right Chaps,
The fine guide someone posted on oil changes said jack the front end up on axel stands to make it easier to get at the sump plug
Is it not better to drain the oil with the car on the flat, so as to ensure the sump is fully drained, or is the sump plug at the back of the sump, so hence doesn't matter if the car front is jacked up.
Cheers all:)
evertime i have changed the oil ive jacked it up from the passenger side and drained it that way...never had any probs
Mattieuk said:
Right Chaps,
Cheers all:)
might help!!
http://www.cliosport.net/forum/showthread.php?t=131027&highlight=182+oil+change
