Power Tool Perverts
Turd Pocket
  Cumpact
Spanner wise, was using a set of snap on flank drive spanners at my mates garage on sunday..game changer. Open end just grips and no slipping. I want a set badly but cant be fcuked spending the money.
what about the halfords advanced ones?
Im pretty new to the tool stuff but for the money, surely you cant go wrong? Ratchet is where its at too.
Youll know better than me though, judging by some of the stuff I see you post!
Flob
Tools for you?
Halfords Pro (maybe called advanced?) stuff is pretty much UK DIY mechanic standard equipment, its good gear!
The halfords spanners aren't bad/poor quality but they will spread and round you s**t off if you use the open end on anything too rusty or too tight, the snap on ones I believe are shaped to grip the head of a bolt/nut more better and probably splay less, there's a good spanner test on youtube, the jokers did well but not outstanding with regard to torque, they are just really nice to use and have the little nut holding plate thing which I like.
I really like Wera stuff.
Turd Pocket
  Cumpact
Tools for you?
Ahhhhh. So many mentions of Nuts. Joy.
Yeah, they'll just me for me. I only have some very very basic tools at the moment as I (stupidly) sold my Kirkland multi set box to my dad as he liked it. Im going to be buying the Halfords Advanced stuff in the foam trays as ive got the halfords tool chest so it satisfies my OCD having everything neatly in there. But, yeah, dont get me wrong id definitely go and blow a grand on Wera stuff in a heartbeat if I could.
For circa £250 I can get almost every hand tool id ever need from Halfords - with a lifetime warranty too. Cant really argue with that considering a SnapOn set of spanners is almost that much :LOL:
Flob
Have you got a trade card?
Brigsy
  T.Turbo
Halfords are good and i have loads of halfords bits, price using trade card is spot on.
The snap on flank spanners as @Touring_Rob said have the open end shaped so they bite hard and dont slip. I try not to use open end but sometimes needs must and these were mega especially on a tight bolt. No slipping or smashed knuckles.
Any recommendations for a decent alternative Rob? Ive got a couple of joker spanners but as ratchet never used open end in anger
Turd Pocket
  Cumpact
I hadnt even thought about it slipping! You learn something new everyday - like the day I tired to use a cheap adjustable spanner to undo a tight bolt and it just span and fucked the bolt up....yeah, lesson learnt :LOL:
Brigsy
  T.Turbo
Yep been there shredded the knuckles not the best :LOL:
Im very sceptical on how good branded tools are compared to cheap, but the snap on impressed me enough to want to get my money out.
Mr Trailer Man
Aye, you can't argue with Snap-on hand tools tbh. No wonder some try to copy them.
Sometimes hard to justify the cost, but in most cases they do warrant it.
That's not to say that there aren't very good alternatives out there.
Brigsy
  T.Turbo
Cheers, I’ll get one ordered up at that price lol.
Adaptor turned up, works spot on.
Totally agree. Cost aside, ive not been dissappointed with any snap on gear i own, all been really good.
jenic
I got a similar adaptor to the above for my inflator, I wish I'd got one with a little release valve built in though to let air out too.
Brigsy
  T.Turbo
Seen them ones too, might buy one. Will the inflator let air out itself if you knock it down a few psi? Ive not tried to knock the psi down yet.
Loaded you are Jon 💰
Was loaded :LOL:
just get two 2ah battery’s..
There’s a reason women got given two t1ts and not one single super boob.
That wisdom applies.
2 x 2ah is how i roll currently:LOL:
jenic
No it doesn't, hence wanting one with a valve.
Do you have a link to the one you've seen? I remember seeing them a while ago but looked today and couldn't find any.
  R5gtt, 182, volvo...
Had these 12 years I think… I’ve been a red tool w&nker longer than you can dream of.. i got the shirt, the heated hoodie, the tools, I might have a Milwa tattooed on my sausage for all you know.
jenic
I like the quick thumb catch ones on my air gauge…
Those ones I fumble and quite often I have to put another 10psi in as I’ve let it all out before it’s come away.
I agree, I have the thumb ones atm but I haven't seen any of those with a release button/valve thing on too.
Brigsy
  T.Turbo
Am I missing something? why are you wanting one with a valve that releases air when you can put in the inflator exactly what pressure you want?
Lower pressures. Saves using the key to push the valve core in.
Been looking for the thumbnail type but not seen any.
Jamie86
  RS175,595,205gti,172
Have you checked the pressure against a proper gauge? My makita one is 2psi out.
Mr Trailer Man
As long as you use the same gauge every time, it wont matter if it's out compared to another.
My Halfords pump is 1-2psi out compared to my Longacre racing gauge, but i always use that to check pressures so the readings are relative to me.
dann2707
That doesn't make sense at all lol
If it's out by 25psi I'm not gonna pump them all up knowing they're 25 psi down but all relative so it's ok 😂
Mr Squashie
CSF Harvester
  Clio 182
How many pumps and gauges do I need? I've only got one pump and one gauge, are my tyres going to explode? 🤔
Brigsy
  T.Turbo
From using various tyre pressure gauges most differ a couple of psi. Same for boost gauges and even some map sensors. QC issues, never going to be totally accurate unless you spend a small fortune on something calibrated.
