Prima racing crank pulley
mikekean
  996 C4S, 135i, E30x2
Thinking of getting one of there Aluminium crank pulleys while i have the engine out of the cup car. Does anyone have any experiance of them?
Ive noticed the standard one has a rubber damper in it, but the prima one doesnt. Is this actually needed? i dont want to buy one then have issues further down the line.
http://www.primaracing.com/ProductDetails.aspx?pid=27874
Mike.
  340i
Prima are a good engineering company.. got some old school boys that work there, I've never had a problem with them :)
  172 Ph1
I've just ordered my genuine crank pully,the rubber part is a Vibration damper
it reduces transmitted engine noise.
Solid one who knows wot would happen.
Crank failure is the main side effect. Certainly K20 and 2ZZ engines are extremely sensitive to changes in the crank dampers effectivness.
mikekean
Ok ill give it a miss then. The billet steel flywheel i just bought for it wont have a negative effect will it?
