problem
  mk2 clio 172
recently installed some ice and when it is turned up loud for a long period of time the sub keeps cutting out for a few seconds any help on why this is happenin.
nope if it is power you need a better alernator
but it could just be thermal cutout you really needs to monitor when it does it and see if its at a fixed point
  mk2 clio 172
i have checked and it is rather hot but it just seems hot all around not in 1 place. How can i fix this at the minute the amp is attached to the sub box. If it is the power would a better battery do the trick.
no battery only works when the engine is stopped all the rest of the time its the altenator bud
if its heat try mounting it flat so heat rises away from the surface
